Do I need a Tune??
Old 09-23-2006, 02:13 PM
rob2269's Avatar
Default Do I need a Tune??
Is it absolutely necessary to tune my car right after swapping out cams...I plan on tunning anyways, but not right away.2000 C5 A4
Old 09-23-2006, 02:20 PM
ZL1Killa's Avatar
if it is running fine and you can have someone look at your AFR using a wideband and it is 14.x around part throttle and what you want WOT, then you are fine.
as long as it isn't a big cam you will be fine. if it is idling funny and surging then you need a tune (Driveability and other issues will be solved)
seriously buy a wideband if you don't already have 1.
www.dynotunenitrous.com ; and talk to Dean. Grab you an LC-1 and leave it in the car
