Flashing a replacement PCM
The PCM took a dump in my buddies car. Does a new PCM have to be flashed with a Tech 2 or can I do it with HP tuners? Can you do a entire write of a blank PCM? Or do I let them flash it then pull out the new calibration and copy all the chnges from the .bin file that we had created for his car into the new stock .bin file. It sure would be easier to just load the last .bin file that had the car running great. BTW it's an '02 TA.
