IFR and Boost Reference Regulator
Old 12-12-2006, 11:49 PM
Deckhand's Avatar
Default IFR and Boost Reference Regulator
I have mototron 60's and an aeromotive boost reference fuel pressure regulator (running a 6.0L with vortech)..
what do I exactly need to do to set up my IFR tables correctly in HPtuners? Right now its running SUPER pig rich whenever i get into boost.
Any help would be GREATLY appreciated.
thanks
Old 12-13-2006, 12:34 AM
Deckhand's Avatar
would it be 69.28 across the board?
Old 12-13-2006, 12:44 AM
RedHardSupra's Avatar
what fuel pressure are you running?
Old 12-13-2006, 12:51 AM
Deckhand's Avatar
58psi
Old 12-13-2006, 08:06 AM
Moderator
jimmyblue's Avatar
It would be a table with the 0 vacuum value throughout
(no change w/ vacuum). That value depending on what
you have for real pressure and flow reference pressure.
You probably want to do a similar dressing of the injector
offset table to remove the vacuum dimension there (but
keep voltage). Though offset data is difficult to come by.
Though
Old 12-13-2006, 02:14 PM
joecar's Avatar
Remove the reference hose and measure the rail pressure (58 psi);
note any variations with RPM, and take the average.
Then calculate:
flowrate
= rated_flowrate * sqrt(pressure / rated_pressure)
= 60 lb/hr * sqrt(58 psi / 43.5 psi)
= 69.28 lb/hr
which is as you calculated;
Then use this value flat across the IFR table, as Jimmy said.
Don't forget to reinstall the reference hose.
Quick Reply: IFR and Boost Reference Regulator
