tach lead wire ona 98 T/A
pretty much what the title says i need to know what wire to hook my tach into to get it to work. its a monster tach w/recall if that matters. it was already in the car when i bought it but since the motor was blown he had everything unhooked and i cant find where he ad that plugged into. any help or answer would be greatly apprecaited. thanks for viewing.
- Scottie dont
- Scottie dont
I am looking for the same info/....
except where is the connection located at??
the PCM
it says the #35 {upper connector} pin and the wire should be white in color.
for gauge power use pin A3 it uses a fused ignition feed.
for ground it shows B15 .....
where is these connectors located?
Hope this helps
These pin outs are for a 98
the PCM
Hope this helps
