P0342 camshaft position sensor low input?
Moderator
Believe the cam sensor is at the rear top of the
motor. Might try to feel around for loose connector
or wire harness damage.
In general stuck-low faults mean an open circuit
in the wiring, or a loss of power. Are there any
other sensors complaining about stuck-low? If so
that might be ENG SEN fuse but a single bad one
probably is more localized problem (wiring or the
sensor itself, just bad or come loose; magnetic
pickups can be fussy about positioning / proximity).
