First startup tune... (HPT)
I am going to be firing up a built 347 here in the next week and found a tune with similar mods to base off of. All I am looking for is something that won't hurt the motor. I will be tuning it with a wideband as soon as I get it on the street, but I don't want to hurt the motor in the mean time.
This is the tune I found...
Has all the same mods as I do, cam is similar in size.
The only thing I can't tell is the MAF used? (very important) and the size of the injectors scaled? I am going to be running a stock LS1 maf until I tune in SD and I am running 42s at 58psi.
So would it be ok to throw in a standard 42s table, and a ls1 maf table and go from there with this tune or should I look elsewhere?
Before I'd even do PE stuff I would jack it up quite a bit of course. But does anything else look out of the ordinary with what I would change to fire up my car?
Thanks for your time
Link to specs....
http://www.v8rx7forum.com/v8-rx-7-bu...ld-my-own.html
Link to specs....
