Surging @ idle when cold and temp gauge slight bounce
Old 05-31-2007, 07:26 PM
Eagle02's Avatar
Default Surging @ idle when cold and temp gauge slight bounce
Hey all-
All of the sudden last week my car threw a P0128 code. Its related to the thermostat and or the ECT sensor. It than began to surge at idle when cold in the mornings. I decided to just pop in a new ECT sensor, but its still surging when cold.
Also, when its cold and surging you can see the dash temp gauge going up and down, varying probably 40-60* (within full cold and 210*) at any given point until the car gets to temp. I don't have a scanner tool at my disposal, so I can't really see what else is going on when this happens.
No additional codes have been thrown since I replaced the sensor.
I could take it to the dealer to get it fixed under warranty, but I'll have to pull the Harris Speed Works system out first...
-Eagle
Old 05-31-2007, 10:16 PM
Moderator
jimmyblue's Avatar
If the ECT sensor connector goes flaky you will get a lot of
weird effects (spark and fuel and idle airflow adders pushing).
Can you scan the ECT reading while it's misbehaving and see
if it's unstable? Could be the harness / connector and not the
sensor itself.
Old 05-31-2007, 11:00 PM
Eagle02's Avatar
I dont have anything to scan with, but I do have a multi meter. Think I could ohm it out to see whats going on?
There is supposed to be a test you can run on the harness too, by jumping the connector with a 3amp jumper wire. Sounded kinda scary to me tho, so I haven't tried.
Old 05-31-2007, 11:04 PM
Eagle02's Avatar
Otherwise, whats a good straight scan tool I can use for reviewing live data? Maybe its time to get something like that.
Quick Reply: Surging @ idle when cold and temp gauge slight bounce
