do i need a bigger maf
does anybody think my 1999 maf will be a restriction???my setup is
ported fast90 / ported ls2 90 mm tb
afr 205 milled
230/236 cam
lt headers
no cats
cat back
3500 tci ssf stall
3.42 gears
slp pulley
would like to buy it before my car gets tuned...thanks
1999c5a4
afr 205 milled
230/236 cam
lt headers
no cats
cat back
3500 tci ssf stall
3.42 gears
slp pulley
1999c5a4
Moderator
About a gajillion repeats of this question are to be found in
the PCM Tuning and External Engine sections and the short
answer is "no" if the screen is removed. But if it will ease
your mind you can go with a Z06 MAF which any tuner worth
the wage ought to be able to deal with, no prob.
LS1 Tech Administrator
I gained 5 rwhp by dropping my 85mm MAF and going to a straight tube on a 500 rwhp engine. I would expect some kind of gain with you ditching a 75mm MAF for something better flowing. The trick is to log your MAP sensor readings and see if your KPa readings drop (pulling vacuum) at WOT. With the 85mm MAF, my WOT pulls would go from 101 KPa to 97 KPa. After I ditched the MAF and added a 3.5" straight pipe, my KPa readings would only drop to 98. I gained 5 rwhp. Same A/F ratio.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Moved from Advanced Tech.
__________________
