Need help, car threw some codes..!
About 2 months ago my car sat for awhile, so I jumped it and when it started I threw P0135, P0200, P1153. After about 2 minutes the car felt normal and no more issues. I wrote down the codes and reset the pcm due to emissions check was coming due in a few days.
Today, I was on my way to work, taking off from a stoplight 1/2 throttle and car sounded funny..power was less and seen the check engine light blinking on dash. I was getting ready to pull over and engine sounded normal again and all was good. So I checked the codes and this is what it set off. All these were set off at the same time.
P1416 Air system bank 2
P1153 Ho2S Bank 2 sen 1 insuff switching
P0300 Random multiple cyl misfire detected
P0200 Injector Circuit cylinder Malfunction
P0135 02S Heater circuit bank 1 sensor 1 malfunction
Ok, I looked at other posts and ones with simular codes never had responses... I know the p1416 is the check valve, but would that cause all the other codes to throw at the same time?
you can forget about the 1153 and 1133 crap..that happens eventually. 2 whole months....hhmmmmm sounds like some wires came loose amongst things. i would check all your ignition coil wires/ spark plug wires/ spark plugs/ and oil just for the sake of things. also check 02 wires and such. you don't have any leaks anywhere do you?
As far as I know everything is ok. I might have a slight header leak on the drivers side. All these happened at once, so has to be something first that caused the chain of codes to throw. I will look over the wires and make sure they are not loose. The other time that I threw the codes was after car sit a really long time, as soon as it started the codes threw. This time I was at a stoplight and getting ready to go 1/2 throttle +, then I heard a sound(kinda like muffler was clogged), a muffled sound, not the same healthy tone it normally has. Then I seen the check engine light flash about 7 times, I slowed down and the flashing went away and car ran normal. On my way home I went WOT a few times and all was good.
