Help: 2k idle and hesitation
I know I have thrown a code for a bad Oxy sensor but it never gave me a prob till now.
Car wants to idle at 2k any time there is forward momentum.
After making a "complete" stop, at a light for example, it will wind down to 1k. But while moving, any time I hit the clutch it jumps to 2k. If I am moving forward, in or out of gear, it wants to hang at 2k. Even a high gear, will pull its way to 2k, making me hit the brake sometimes to slow her down to the speed limit!!
There is also a slight hesitation at low light throttle at low RPM.
Very annoying!!!
Anyone?
Oxy?
Bad gas?
Plugs (is there an easy one to pull and verify?)
Tune went nuts?
What gives?
Thank you.
I just picked up the 02 and will get it changed.
What can read that without getting nailed by a tuner?
also, update:
I cleaned the TPS Sensor
and IAC sensor (this was pretty dirty)
STILL does it!!!!!!!!
If I nail it, no problem.
But if I want to coast to a red light, nope, 2k if I'm rollin
Thanx frost!!!
Its a Nick William.
I havnt checked that, but wouldnt it stay at 2k even if I stop?
Even if I am not on the throttle, if I tap the clutch, it jumps right up.
Whatever is off whack seems to know when I am at rest and in motion.
I still say vacuum leak; it's not an uncommon problem.
aghhhhhhh
Any idea where to start looking or what to look for?
car sounds like it is sucking in all kinds of air.
I thought it was the H/C but it sure ingests alot of air.
Any specific hose to check or how to?
like any vacuum leak.... get it idling and spray around with carb cleanrer; listen for the idle to change and you've found [a] leak.
doh!!!!
awesome, thanx Frost!!!
