HELP! URGENT! I've got errors during a full reflash. What what should I do?
I'm using EFILive V2 with software version 7.4 without the "Use high speed" button (I've heard that this reduced the possibility of error)
I started a full reflash to get my 2000 operating system up to 2002. About 1 minute into the reflash I get this repeating error in which the values of numbers to the left change.
14:30:45.421: Error: Failed. Controller has returned to normal operation, please retry the operation.
14:30:45.421: Retrying previous block
It's been going for about 10 minutes. Should I wait? Should I disconnect via software but leave the FlashScan controller connnected?
Problem Solved!
I stopped the process via software and restarted it with the same error using the "non-high-speed" mode. Then I switched over to "high-speed" and everything worked fine.
