Sometimes easy... just isnt easy...
Old 07-07-2007, 11:51 AM
Nakoz's Avatar
Default Sometimes easy... just isnt easy...
Ok, i was following MrDude_1's write up on "How to Log your WB w/HPT w/o EIO" and was wondering if I can use the ground on the A/C pressure sensor to use as the ground for the White and green wire grounds on the LC-1 WB.
I know the blue heater wire is a separate ground so I put it on the battery, but I am not sure if I can use the grey wire from the A/C pressure sensor as a ground to the PCM.
Any advice?
