Could an exhaust leak cause P0155?
Old 07-15-2007, 06:07 PM
Marc '99T/A's Avatar
Default Could an exhaust leak cause P0155?
I know I have a leak at the collectors on the passenger side; could this leak be causing this code?
Old 07-15-2007, 09:06 PM
Shallow Bay's Avatar
It could, especially if no DTC are being thrown by the driver side O2 sensor. With that said, I still feel the code is being set because the heater is not staying warm enough due to the LT's.
Old 07-16-2007, 07:35 AM
But everything was fine before the H/C install. Put everything back together and now this.
Old 07-16-2007, 12:15 PM
Coincidence? Probably not... fix the leak and see where you stand.
Old 07-16-2007, 08:11 PM
Corvettekid82's Avatar
I have the very same issue.. threw the P0155 for the pass side and I have a leak on that collector as well. I dont know for sure if the two are related to eachother, but its hard to think its all coincidence.
Quick Reply: Could an exhaust leak cause P0155?
