flip a switch to a different tune
Old Jul 14, 2007 | 05:08 PM
Emoney97ss's Avatar
Default flip a switch to a different tune
my tuner said that he could wire my car to flip a switch and it would automatically tune the car for the nitrous... i was wondering if anyone has heard of this and what you guys think?
Old Jul 14, 2007 | 05:45 PM
brad8266's Avatar
yes you can do that. You can wire in a potentiometer and when you hit the switch the PCM will pull a few degrees of timing.
I think EFILive has a OS that can pull timing for nitrous also.
Old Jul 14, 2007 | 06:39 PM
2002_Z28_Six_Speed's Avatar
EFI-Live COS-5
Old Jul 15, 2007 | 10:00 AM
z-ya's Avatar
Timing tuner works also.
Old Jul 15, 2007 | 10:04 AM
Eurospec2's Avatar
EFI LIve COS-5 pulls timing and adds fuel at the flip of a switch!
Old Jul 15, 2007 | 10:28 AM
minytrker's Avatar
Originally Posted by 2002_Z28_Six_Speed
EFI-Live COS-5
works really well
Old Jul 15, 2007 | 10:53 AM
Frost's Avatar
You don't need a special OS.... A resistor can be used with a relay to force the IAT's input into an unused area; this will allow changes to both timing and fueling (via PE modifier) that are active only when armed.
Old Jul 15, 2007 | 04:37 PM
Emoney97ss's Avatar
is this the best way to tune a dry shot?
Old Jul 15, 2007 | 05:24 PM
VH5150's Avatar
Dynojet Fan
Good idea....what the hell is EQ ratio tho... its used in efilive under pe modifier IAT table...
Old Jul 15, 2007 | 08:20 PM
Frost's Avatar
EQ ratio is Stoich / target AFR ....... 14.628(stoich) / 12.8 (desired AFR) = EQ of 1.143.
Once your VE/MAF are calibrated you will hit your target EQ
Old Jul 15, 2007 | 08:55 PM
Doc's Avatar
Doc
Tuning for a "dry" or MAF related/compensated shot of N20 does not require anything other than a spot on MAF tune. You will be limited on how big of a shot that the MAF can compensate for. Typically most consider the 150 shot, the max for the dry shot.
With proper safety equipment the "Wet" shot will support a bigger hit for sure.
The EFI Live Custom OS, which is free, can pull timing and add fuel independent of the MAF or IAT settings-which, in order to get max motor performance should be left alone(besides an adj pot with the IAT).
You can pull timing by flanagling the IAT settings with a switch or pot.
For the OP, what are your overall goals for the car? What mods do you currently have? What do you expect/need the N20 to do?
Old Jul 15, 2007 | 10:41 PM
Originally Posted by minytrker
works really well
Working on mine right now.
Old Jul 16, 2007 | 01:46 PM
Emoney97ss's Avatar
ok i'm about to be running a f14 with 5.3 prc heads... electric water pump, long tubes, ls6 manifold, under drive pulley, every single bolt on possible except a 90/90 i'm trying to get above 550 with a 125 dry hit... is this possible? or should i say forget it and go wet?
Old Jul 16, 2007 | 03:46 PM
Doc's Avatar
Doc
With a good tune, sure why not? Will the rear put up it? Eh???
Old Jul 16, 2007 | 11:16 PM
Emoney97ss's Avatar
it might if i'm lucky hahah... i don't plan on going with slicks just for the street with dr's...
Old Jul 17, 2007 | 12:17 AM
VH5150's Avatar
Dynojet Fan
cool, good ****...
BUT the key word is "calibrated" how many peeps have their VE/MAF calibrated???
Old Jul 17, 2007 | 12:51 AM
Emoney97ss's Avatar
wow i think i was in over my head when i asked this question because i don't understand half the words in this thread...
Old Jul 17, 2007 | 01:02 AM
Beer99C5's Avatar
Originally Posted by VH5150
cool, good ****...
My MAF and VE is dialed in.
Pretty much anyone with HPT, EFI Live or other software that logs and allows access to change the tables can calibrate their MAF and VE tables. Its the basis of learning tuning.
Old Jul 17, 2007 | 01:45 AM
Frost's Avatar
cool, good ****...
yup
