HPTuner bin for 224/228 + AFR205 + M6?
Doing my heads and cam install myself this weekend with jmilz28. I've got HPTuners warmed up but am looking for a bit of assistance with tuning.
I plan on doing this myself from scratch with what I am learning. However, this would be easier if I had something close to start from. Would anyone be willing to help a broseph out?
Thanks much,
Zain
Thanks much,
Zain
If I wasn't running SD, you'd be more than welcome to my tune, which is a 226 cam but there shouldn't be too much difference and it would be a good starting point. Might be hard to use someone else's tune if you don't have a wideband to verify things with but you probably knew that already.
Thanks much,
Zain
Thanks much,
Zain
Originally Posted by 02SOMWS6
My bin file would be perfect cause I have the same cam but something about paying someone top dollar to tune my car and he spent more than half the day tunning on the street and the dyno then just to hand that over ......... Your car will run untuned with that cam, it's not like that cam is so radical that it has to have a tune to run. My set up made 452rwhp and 408rwtq threw a 12bolt with 4.30 gears and a heavy steel driveshaft.
Zain also has a wideband in hand.
