wb sensor location
It's not like a MAF so turbulence doesn't matter so long as it is in the exhaust path. Obviously the best would be 8 sensors, but if you are going to use 1 having it there is not a bad idea. Personally I would prefer to keep it on 1 bank so that you can isolate any problem (put a bung in both sides and you can move the sensor to check).
