Reprogram PCM or LIVE Tunner?
Ok, I'm building a custom motor that the only real thing on it that is a "stock" part on it is the block, and maybe the heads but thats going to be an Aftermarket GM part lol. so should i have the stock ecu programed or get the Real time PCM?
well i remember a gm high tech were they have a place that takes stock ecus and makes them real time tunnable. so i'm debating between that or a fast, but if a stock ecu will work thats cool. but i just dont want to have to send it in again to have it reprogramed if i change something.
The real time tuning you mentioned above is EFI Live using the moates Roadrunner PCM, best money i ever spent on my car.
HPTuners or EFI Live will be unphased by changing your stroke, they can handle pretty much any insane combo you can think of
