Radio and Windows stop working?
I have had an intermitant problem where I could be driving and the radio and power windows will just shut off and not work for a bit, then it will come back. I have been told it could be the bcm (body control Moudule). Could it be form the aftermarket alarm I had installed? a ground? or do I just need to have the BCM replaced?? Any help is very much appreciated.
I've had this exact problem for a while, and I've tried everything short of buying a new BCM (I'm a cheapass) and here's what I've found.
Spazzy BCM Workaround
(For those lazy bastards who just don't feel like fixing/replacing theirs)
When you notice the radio/windows are out, hold down your window switch (up or down) and press your door lock (lock/unlock it doesn't matter) If you do it right, everything should turn back on. If it doesn't fix the problem the first time you do it, simply try it a couple more times.
I've only encountered one or two times where this didn't work.
