PE versus injector flow.
Old 06-26-2003, 06:41 AM
StevieZ's Avatar
Default PE versus injector flow.
If I change my injector flow, will that change the PE at wot settings?
Old 06-26-2003, 08:59 AM
Brains's Avatar
Default Re: PE versus injector flow.
How about a big, reounding "It shouldn't" ... But it likely will at least to some degree.. The PE vs Temp table is an adder (subtractor actually) to your "calculated" A/F ratio.. The PE vs RPM table is a multiplier (divisor actually) to calculated A/F ratio... So theoretically if your injector flow rate table matches the injector, and your injector offset table is close (less critical at higher RPMs anyway) it *should* fuel just fine. Real-world experience says it's probably not going to be exactly the same, but it should be close.
