autotap ?'s
autotap ?'s
BLM's aren't listed under dialog captions. When the program communicates with he pcm it quits looking for parameters before the % bar is complete. Also my LTFT's are at 0 under load and flucuate between -2 and -6%, should they be at -2 or so at WOT. 02's are anywhere between 830 and 850 WOT, 25+* of timing under load and 0 KR. Also, AF ratio is between 13.3 and 12.9 underload.
Re: autotap ?'s
If your LTFT are negative, then they will go to 0 when you're at WOT. Pay no attention to AF ratio in ATAP. That's just commanded AF. On your O2's, only pay attention to B1S1 and B2S1. Those should read between .890 and .920 Lower, you're LEAN, higher, your RICH. You'll have to call ATAP about it not looking for all the params before stopping.
