IAC counts too high how do I lower w/o drilling hole larger?
Finally broke down and bought EFIlive V.5, since ATAP v 2.4 won't read IAC counts. Now when I read them, they are around 68 at idle, Hole is already drilled to 1/4" and I am having trouble ramping down to idle when I drive and come to stop. Signs that the hole is too large to start with. Idle is set at 850 in park and 650 in gear, seems to idle fine, thou smells rich. Question is how do I lower IAC counts w/o drilling?
Thx In Advance
Thx In Advance
I dont think you can. You are supposed to drill little by little until they are around 20-40. 68 is still way too much. If you are worried about the hole getting big, start a second small one.
Yes but,I am having trouble ramping down to idle when I drive and come to stop. Signs that the hole is too large to start with.
i saw a post for this i will try to find it, there is a few parameters in ls1 edit that help control the ramp down.....
