Ohm output on a ls1???
Old 01-13-2008, 09:02 PM
Demonicbird00's Avatar
Default Ohm output on a ls1???
ok i was wondering what the Ohm output is on our motors? anyone know or able to point me in the right direction??? i think i may have stumbled onto something...good that is
thanks
brandon
Old 01-13-2008, 09:05 PM
edcmat-l1's Avatar
thanks
brandon
WTF are you talking about? Ohm is a measurement of resistance.
Do you mean what is the output in WATTS? WATTS is a measurement of power.
Old 01-13-2008, 09:10 PM
1Hotbird's Avatar
Im also confused what are you ohming out? ac blower motor?
Old 01-13-2008, 09:34 PM
whooops sorry im mean what is the output of volts through the spark plug wire?
Old 01-14-2008, 04:23 PM
edcmat-l1's Avatar
Secondary output voltage is dictated by secondary resistance. The higher the resistance, the more spark energy required, the more voltage output by the coil/s. If you want to know the max they are able to put out, I think its in excess of 50,000 volts, but I'm not exactly sure. I know its up there. If you want to know the amount they put out regularly, its in the neighborhood of 20,000 volts.
Why, what do you think you're on to?
