help with hp tuners pro or standard
I have saved up enough xmas money to order hp tuners for my whip..
i decided just to order it rather then spend the money to add credits to someone cable balh balh
my car is 99 ta m6 76 single turbo built 370 yadda yadda
i want to tune the car with the sd tune 2-3 bar...
i want to order the hp tuners..but
why would i want to order the pro version what does that give me over the cheeper version??
Black box logging (log w/out laptop) and inputs/outputs. Inputs are good for things like fuel pressure gauge, Wideband. Outputs can be used to actvate external signals (example, if RPM > 6000 and KR > 3 AND ..... turn a light on)
Anything w/a linear feed (and below a certain amperage) of 0 up to 5 volts (doesn't have to go this high, just not over) can be mapped w/the scanner and added in
For your set up, it would be a nice option to have all those inputs with the Pro Interface. Figure you'd really benefit from being able to log wideband and fuel pressure, don't really need boost since the MAP can show that.
