Predator mess up dyno tune?
Old Jan 20, 2008 | 12:30 AM
DustinWS6's Avatar
Default Predator mess up dyno tune?
So my car has been dyno tuned. Awhile back I put a 160 thermostat in my car and used the Predator to have the fans cut on earlier to take advantage of the new stat. My question is, did running the Predator affect the tune that was done on my car.
The reason I ask is because I have been getting the random/multiple misfire code lately. I have a cam in my car and it has a 11LSA so I thought it could be an issue with the knock sensor.
Thanks for the help.
Old Jan 21, 2008 | 08:44 AM
06MonteSS's Avatar
LS1Tech Sponsor
if you just selected the Factory HP Tune and modified the fans in that and installed it, then no - it should not have changed anything else in your dyno tune. The Factory HP Tune just lets you modify the tune that is currently in the car and does not install any of the diablo tune changes.
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Jan 21, 2008 | 10:59 AM
01Z28M6's Avatar
If you're not actually getting a misfire then the predator should be able to help you with that too as it can correct that particular dtc reporting.
Old Jan 21, 2008 | 12:42 PM
sprayjunkie's Avatar
You did not install the performance tune from the Predator, did you?
Old Jan 22, 2008 | 11:24 AM
DustinWS6's Avatar
How do I go about doing this?
Hell no. I'm not that dumb lol
Old Jan 22, 2008 | 11:31 AM
OK, then if you used the factory hp tune, there should be no issues related to the tune.
You could always restore the stock tune to the car to see how it runs with the Predator removed.
Old Jan 22, 2008 | 11:33 AM
01Z28M6's Avatar
To answer this I need to hook up my predator and go through the menu system. Right now is not a good time for me. I will try to get to the car (in storage) tomorrow.
06MonteSS is the predator expert in my opinion. Can you guide him along Lewis?
Old Jan 22, 2008 | 04:40 PM
DustinWS6's Avatar
Removing the Predator tune from my car wouldn't hurt the tune that my tuner did on the dyno?
Old Jan 23, 2008 | 11:01 PM
DustinWS6's Avatar
I had installed the Predator tune to my car a long time ago. Then I had a cam installed and they dyno tuned my car. After the dyno tune I installed the stat then re programmed my fans using the Predator.
Also could you shed any light on why I would be throwing a mis-fire code?
Old Jan 24, 2008 | 07:25 AM
06MonteSS's Avatar
LS1Tech Sponsor
well, it depends... did you ever restore your stock/OEM tune to your car BEFORE you got the dyno tune?? if you did this, when you went to modify the fans, it should have saved your dyno tune as your original backup now..
if you did NOT do that and your original OEM tune is the original backup in the predator, then yes, if you restore the stock tune that is saved in your predator, it will overwrite the custom dyno tune...
no clue about the mis-fire code...
__________________
Old Jan 24, 2008 | 08:52 AM
01Z28M6's Avatar
Cam changes, especially with big ones result in misfire codes; at any rate, I have seen this before. I don't know technically why but this has come up before. I would do a search on "misfire code cam" and see if anything bubbles to the surface. Just a little light, sorry.
edit:
I did a search, loads of threads....
Old Jan 24, 2008 | 11:14 AM
wait4me's Avatar
If you got it custom tuned at a dyno they probably shut off the missfire detection at low rpms as if you dont it will make a missfire show up even though there really isnt one.
But it looks like somehow, either they didnt do that or you put in the preditor tune and it over wrote the tune and turned the missfires back on.
Old Jan 24, 2008 | 02:34 PM
DustinWS6's Avatar
I did NOT restore the stock tune to the car before the dyno tune. I was meaning to but completely forgot before I dropped my car off.
So you're saying that my it could have stored my dyno tune as my back up tune now? Should I try reseting it to the back up tune?
Old Jan 24, 2008 | 02:35 PM
DustinWS6's Avatar
He tuned it correctly and I had no problems until I changed the fans to come on earlier.
Old Jan 24, 2008 | 02:52 PM
06MonteSS's Avatar
LS1Tech Sponsor
"So you're saying that my it could have stored my dyno tune as my back up tune now? Should I try reseting it to the back up tune?"
nope.. cuz since the original backup wasn't restored before, it still had the original oem backup tune in there...
so when you went to change the fans, it didn't create a new backup - cuz it still had the other backup in there.
__________________
Old Jan 24, 2008 | 02:54 PM
wait4me's Avatar
That is what im thinking, The pred just modified the tune already in memory and it just overwrote your tune you had without saving it again. The unit just assumed that you where still stock, It doesnt have a way to check. So that is why your missfires are now popping up because it just put its stuff back in and over wrote what was in the pcm.
Old Jan 24, 2008 | 03:09 PM
DustinWS6's Avatar
So basically I'm screwed and will have to deal with the annoying CEL?
The car still runs good and idles fine though
Old Jan 24, 2008 | 03:24 PM
ringram's Avatar
You could always buy a proper tune tool and turn it off
Old Jan 24, 2008 | 03:37 PM
DustinWS6's Avatar
Kinda hard to buy anything for myself when I'm still in college and only working part time
