Showing P1416?
Showing P1416?
I have an exaust leak, and I am showing code p1416, it said Auxilliary Emission Controls. Auto Zone couldn't tell me anymore, the dealer is closed, so does anyone have an idea what the code means? I haven't pinpointed the leak yet, it is on the passenger side of the engine, if it is from the manifolds, I am going to buy headers, but I am not sure what is going on yet.
Re: Showing P1416?
AIR INJECTION SYSTEM
P1416 HO2S sensors indicate lean condition present
when AIR pump is turned on during closed loop
operation when:
HO2S sensor < 222 mv for >= 1.2 seconds or fuel integrator delta of .14 to .17 counts
(depending on long term fuel cell) when pump turns on during
No MAF, MAP, MAT, ECT, TPS, HO2S, Purge,
Engine Protection, Fuel Trim, Fuel Injector, EST,
Crank sensor or Misfire DTCs set.
Engine run > 2 sec 7.3 seconds Up to 3 times
Re: Showing P1416?
I too have this code thrown off on my car and was wondering if it is safe to drive the car around until it is fixed and I was also wondering how easy it is to fix because a Chevrolet dealership wants to charge around 300 dollars to fix it (a service person at the dealership says it may be an EGR valve).
Re: Showing P1416?
i do know the air pumps have a small valve, similar to PCV valve and it clogs up. if you can't blow through it, replace. since your code is air pump related this may be it.
i got another thread running here and can't get an answer to my code
