PCM has wrong tire size????
Finally managed to grab a file (took 14 min - is that normal?) and started to play with ls1edit. Mainly want to fix the speedo at the moment 'cuz of the 4.11 gears & Nittos. The pcm seems to think the tire is 3.5% smaller than it is - 25.29 instead of 26.18. Is this normal? Is it a fudge for rolling radius being less than diameter / 2?
Re: PCM has wrong tire size????
Yup, that's normal.
Going by the tire diameter calc it comes out to be slightly larger than what the PCM has.
Personally, I measure the rolling distance and back-calculate to the diameter. Seems to give the best results.
I can't believe 0.83" of squash.
Moderator
Squash might mess with your diameter measurement
depending on where you measure, but there's no
getting around the circumference (heh) - it never
changes, or only as much as you burn off. The belt plies don't stretch on street tires. NoGo's
method seems the right way to get the number.
I get 25.22" actual vs 25.68" nominal for 315/35/17 Nittos, or 0.46" squash. Short sidewalls perhaps.
