MAP pinout to use Innovate 02 Sensor???
Old 08-04-2008, 06:19 PM
Datsun350Z's Avatar
Default MAP pinout to use Innovate 02 Sensor???
Need to know what Pinout to tap into to use the innovates 02 sensor for the car.
Old 08-04-2008, 08:24 PM
Frost's Avatar
what are you trying to do? The factory PCM does not work with a wideband sensor
Old 08-04-2008, 08:53 PM
TAQuickness's Avatar
If you're looking at your NB sensor harness, the black and gray are the signal wires. I do not recall which is the high or low side though. The white wires are for the heater.
Old 08-04-2008, 09:09 PM
Datsun350Z's Avatar
I was told that with the Innovate setup you could use one of the wires coming out of the gauge or the unit, not sure which, and use that as your 02 sensor voltage reading as well? Just something I heard and was willing to try before switching to speed density.
