OBD2 to Laptop USB or Serial Connector
Old 08-12-2008, 03:40 PM
locodave46's Avatar
Default OBD2 to Laptop USB or Serial Connector
Hi, My son has a Predator hand held. Would I be able to connect it up, use a serial cable plugged into the bottom of it, once it's connected to the OBD2 port. To connect it up to my lap-top to get a real time. Or is there a cable I should get, or diagrams to make one myself. USB or Serial. Dave
Old 08-12-2008, 11:08 PM
koolaid_kid's Avatar
Buy a name brand USB to Serial convertor and you should be O.K. There are a limited number of chipsets out there that everyone uses. A name brand will make your chances much better.
Assuming, of course, that you have the software to read the Predator with your PC.
Old 08-13-2008, 03:10 AM
y2khawk's Avatar
Any standard USB to serial converter is all that you will need.
As for PC software, assuming the tool is on the latest revision/hardware, you can download Dataviewer to access real time data through the tool.
http://www.diablosport.com/CMR/softw...er_3.1.7.5.exe
