Can anyone look over my logs?
I have a 93 SD Z28 with a pcmforless tune currently to just get things in the ball park. I'm going to send this to them tomorrow as well.
Thanks in advance...
Oh and my general complaint is that the car is very rich IMO. No crazy smoking but after warm it will puff a bit which I believe is fuel. It is much richer on open loop. Notice how the o2's don't seem to switch much, is this normal?
http://www.fileden.com/files/2007/12...irst%20Run.csv
Wow I haven't seen an Autotap log in years. Correct me if I'm wrong, but Integrator is Short Term adjustments and Block Learn is Long Term adjustments. a 128 value in OBD I is the equivalent of 0; or no correction needed. Lower numbers mean richer, higher numbers indicate leaner (similar to negative and positive numbers for the later PCM's). It's definitely rich, but I can't say how much because I'm used to looking at percentages, not absolute numbers like that. In some cells the "I" values is around 80 which I would guess is very rich. I could dig around some older books to find out. Have you shown these to anyone who has OBD I datalogging experience?
Thanks for looking. I have them posted here and there and sent them to my tuner. Yes they are indeed old since my car uses and EPROM and SD. The car is no doubt rich I just need to figure out if it's safe to drive on while I wait for revisions from the tuner.
I pulled an older book and it reads "Normal operating range for Integrator/short term fuel trim is 115-141 which is plus or minus 10%." It also has a scale for Block Learn/Integrate which indicates 102 is -20% rich and 77 is -40% rich. I noticed there was a range of cells close too that, so yes you are way too rich. I wouldn't drive it until the tune is fixed. Check the oil for raw gas just to make sure.
The oil no doubt had been already getting fuel infested. Can I ask where you get those books like that. I want to learn but am having trouble finding good information online.
http://www.amazon.com/Corvette-Injec.../dp/0837608619
