HP tuners clicky clicky
Old Aug 29, 2008 | 09:43 AM
ls1redline's Avatar
Default HP tuners clicky clicky
Posted in the hybrid / conversions section as well but need your help on how to correct the tach output signal through HP to correct my tach reading. Car was a 1995 LT1 camaro but now has a 2000 LS1 with 2000 harness and pcm? Any help is appreciated. Thanks
Old Aug 29, 2008 | 09:49 AM
Frost's Avatar
setup the gears to match what you have and let it scale, then under engine>general, set tach high and low res to both be 3.
Old Aug 29, 2008 | 10:20 AM
ls1redline's Avatar
You rock. Appreciate it
