RPO Codes
Old 10-23-2008, 12:31 PM
jdscott74's Avatar
Question RPO Codes
Are the RPO codes found anywhere other than the sticker on the driver's door jam?
The reason I ask is because my sticker is there, but the lettering has all faded away, and I can't read it. I think some cleaning chemicals stripped the ink off the sticker at some point in its history.
Have I lost all hope of getting the codes and identifying which options came on the car when it was new?
-- Joshua D. Scott
-- 1999 Formula, M6 (Black), 13.559 @ 106.18
-- http://www.ozzy.net/jdscott/firebird/
Old 10-23-2008, 12:40 PM
xephona's Avatar
Go to a nearby gm dealer with your VIN, they can print out a sheet of all of the car data. Other than that? Unless you have all the paperwork that came with the car, you are out of luck.
Old 10-23-2008, 12:41 PM
2001NBMZ28's Avatar
A dealership should be able to print you out a list from the VIN.
Old 10-23-2008, 01:20 PM
jdscott74's Avatar
Cool! Thanks for the quick answers. I'll try my local dealer and see if they can help.
Old 10-23-2008, 07:33 PM
Zralou's Avatar
My '94 Formula has the RPO code sticker in the glovebox.
Sara Lou
Old 10-30-2008, 01:37 PM
JohnnyBs98WS6Rag's Avatar
Sara Lou
Yep, that is where GM put the RPO decal before they got "smart" and moved it to the vulnerable door location in ~'97 (I think).
Old 10-30-2008, 10:50 PM
Formula350's Avatar
I actually think it was around 95 when they moved it. It WAS a very "smart" move though! The VIN is stamped into metal and riveted to the dash and won't fade or fall off from the elements, yet it's inside the car. Where as the RPO codes are on a sticker in the door jam which is exposed to weather, humidity and cleaning products. And it's not just a bash on GM, since most other manufacturers do this, but the part that is a bash on them is the fact that it was in a FINE location! What was wrong with 3rd Gen location of in the center console? o_0
Quick Reply: RPO Codes
