Gauge cluster conversion
I have a 95 formula and I've been wanting to convert the cluster to the 97 cluster, I've done a lot of searching, but I have not found anything on if this is just plug and play or do I have to do any wiring? Also, does the digital odo read the correct millage?
theres no plug and play, you have to tap or splice into all the appropriate wires, or pins in the gauge clusters receptor plug. Theres a stick in the electronics section with all the pin out information you need. Its more common in mustangs, maybe they can help you through the process. or ask in the elctronics forums
