PROJECT "UNLEASHED" (My 99' Trans Am)
Old 08-24-2012, 09:45 AM
  #161
LT1Formula007's Avatar
Just an update.
Went and made some test passes and had nothing but issues.
I'll talk about it tho as a reminder of what my experience was. :-)
Pass #1 - I launched the car and it blew the tires off and wheel hopped. I let out and rolled back into it and for some reason the car had shifted 1, 2, 3, & 4th gear all by 36 mph and I stayed in it to get some data and it downshifted back to 3rd gear and so I let out around the 900 foot mark when I felt the downshift. It ran a horrible 13.0 @ 118 mph with a 2.0 60' :-)
2nd pass was after making some adjustments in the tune. I launched it and again it spun BAD And wheel hopped so I let out (rather than break something) & it felt alot better when I got back in it and so I made a full pass. However it didnt want to shift into 3rd gear. I back pedaled it and it went into 3rd gear and i matted it again. The car ran an 11.49 @ 128 mph with another horrible 1.9 60'
3rd pass- I launched the car and it felt sluggish at the start and then the tires spun bad. And I just rolled into it after letting up again to keep it from wheel hopping. Then it kept breaking up down the track and at around the 800' mark it backfired and killed the engine. It restarted and I got it back to the pits only to find I coasted to a 12.0 @ 111 mph with a 2.0 60' again.
Needless to say I was very unhappy but it just meant I had some more things to figure out. Turns out my Crank Sensor was getting hot and losing readings and causing the issue with it backfiring and running poorly. I fixed the crank sensor the next day. This was a week ago.
Just this past wednesday, the transmission blew up on my ever so slow cruise into work. :-(
It lost 3rd and 4th gear after a very loud explosion or banging sound from inside the transmission.
So now the Transmission is at RPM TRANSMISSION Getting built.
I'll keep this thread up to date. I can't wait to get thr car back on the road and back to the track to work on the full passes I want sooo bad. I just gotta set up the suspension and get it to leave at that point though.
Wish me luck guys. ;-)
Old 08-24-2012, 09:53 AM
  #162
mud.man.rj's Avatar
Default She's breakin up.
Wow, tough time lately, kind of comforting the trans went in a way, now you can start over and shouldn't have a shifting problem. With those times and all the problems she should really pickup when you get it sorted out...but sounds like your going to have your hands full in the traction department. You will get it for sure, just need more time dialing it in.
Old 08-24-2012, 10:04 AM
  #163
exodus_gs1's Avatar
damn sorry bout the luck man. But hell its a good 2 seconds faster then me with all your problems haha. I'm guessing low 10's, what size and type tires you running?
Old 08-24-2012, 10:25 AM
  #164
Yeah It's definetly a bummer. But I'll get it all straightened out soon. :-)
Traction is going to be a PITA to get under control. I can completely put the tires up in smoke from a 60 mph roll. I have Mickey Thompson 295/55/R15 Drag Radials out back.
I actually have a small video a friend put together for me from the track day. I'll post it here in a minute.
And I'm guessing it will go bottom 10's for sure and once I get some more seat time and everything else lined out, MAYBE a high 9 second pass on motor. At least thats the goal. :-)
If I can't hit 9's NA I'm gonna spray it with whatever it takes to reach a 9 second pass and leave it at that.
Old 08-24-2012, 10:29 AM
  #165
Here is a little Video from my test passes at Muncie Dragway.
Old 08-26-2012, 10:36 PM
  #166
Here are the timeslips from my Test Passes; when I was having Issues with the trans, traction, and crank sensor.
1st Pass
2nd Pass
3rd Pass
Old 08-27-2012, 04:05 PM
  #167
exodus_gs1's Avatar
Good luck with it all and can't wait to see that car running strong
Old 08-31-2012, 07:07 AM
  #168
Thanks brother.
As an update: My transmission came back from rpm transmissions last night and I'm gonna finish putting it in today. Almost got it all done last night but I didnt get home til 8pm and I also had to tear the front of the engine apart to install the new Cloyes timing chain I just got in the mail as well. :-)
So this time around I should be able to sort out all of the tuning, starting, and hopefully even get some more track times soon. :-)
I'll keep this updated and post a few more pics up.
Old 09-03-2012, 11:16 PM
  #169
Here is a pic a buddy took of the car. I thought it looked pretty cool. BUT It Was Dirty.
LS2/LS3 Gen 4 1X Timing Chain Set...
The Engine All Back Together Again!!!
My New RPM Tranmission (Level 6.5) :-)
**Big Thank You To Rodney and Jeremy!!!
My Buddy James and I putting the New RPM Trans And YANK SS4000 Stall in the car...
Close up pic of this Beautiful Trans and My Quick Disconnect Trans Lines. :-)
All finished up and back on the road again!!!
Old 09-03-2012, 11:21 PM
  #170
I'm hoping to get everything lined out with the tune here in the next few weeks. If so, I'll be hitting up the track as well. I wanna try to get some full passes in before the end of the season!!!
This car has really been testing my devotion to the car game. I'll tell you 1 thing... I need a break from repairing it and some quality time behind the wheel. Preferably at 100% TPS aka WOT. lol :-)
Old 09-03-2012, 11:54 PM
  #171
mud.man.rj's Avatar
Sounds like things are coming together alright for you, sure can be trying at times hey james.
Old 09-04-2012, 07:26 AM
  #172
exodus_gs1's Avatar
Man everything looks killer. Gives me hope that one day I can get my Camaro to that point. What's the street manners on that thing?
Old 09-04-2012, 05:30 PM
  #173
Mud.Man, It sure is brother. I have just about had it with this build. Half tempted to sell it or trade it off if I dont get it all lined out by this winter. I can't keep throwing the cash at it that I have been. It's just about to be finished up this month. If it breaks again it's getting put up til I can sort out other priorities. :-/
But I have worked so hard to finish it, I cant really let it go. I'd lose my ***. So it would either be find someone with a c6 z06 who would wanna trade... Thats a long shot, or just let it sit. :-)
Old 09-04-2012, 05:38 PM
  #174
Exodus, The street manners are amazing believe it or not man... My tuner is Great, and that helps ALOT!
The whole setup was spec'd out by myself, seth at ERL, and Brian Tooley- who really went above and beyond with making the engine what it is. I AM MORE THAN HAPPY WITH HIM.
And Everyone else involved with the build.
ERL, BRIAN TOOLEY, MWC, RPM TRANSMISSIONS, And all of the other independant shops I dealt with when buying parts.
Old 09-04-2012, 06:33 PM
  #175
exodus_gs1's Avatar
Hell yea, I want to make mine run 10's and still be my daily. Hell if I got a 10.9999999 id **** and be happy as could I'd. But I don't wanna spray or do any FI. Just an all motor badass lol. But I hope it all works out, I'd help but being like 4 states away can't haha
Old 09-04-2012, 09:58 PM
  #176
An "All Motor" 10 second street car is very doable now days. Hell almost any 400+ CID engine with a set of ported heads and a FAST Intake and TB will get you into the 10's. In an auto car it can be much easier to achieve. 6 Speed cars are traction limited, but can be done as well. Hell my last car had a 403 LS2 Stroker in it, stock 243's, a FAST 92/92, TR Stroker Cam, a yank 4k stall, stock 10 bolt with 3.42's and 16" ET Streets on salad shooters and ran 10.99 at 125.6 mph with a crappy 1.659 60'. It still had Plenty left in it too!
I would do an ls3 416 with some ported heads and a FAST setup. It's expensive, but yet half the cost of my build. ;-) And 10's would be very doable.
Old 09-06-2012, 08:12 AM
  #177
exodus_gs1's Avatar
I was thinking a 427 ls3, with 102/102 setup, and badass heads and run with it. But that first setup sounds sick also. Yea I priced it all out like brand new stuff off the shelf came out to be pretty high so it will be awhile haha.
What kind of weight reduction did you have with that ls2 setup?
Old 09-07-2012, 12:39 PM
  #178
Lightweight carpet, crash support was removed, passenger side air bag, heat shields from exhaust removed and front sway bar. And the rear seats. That was it.
Old 09-07-2012, 09:46 PM
  #179
exodus_gs1's Avatar
damn that's what's up. Did you buy a carpet kit or just lay your own?
Old 09-09-2012, 11:06 PM
  #180
I just bought the black cutpile carpet from Menards and layed it in there. It didnt look all that good and unless you glue it down man theres no reason to do it. Its more of a pita than it worth. Just pull the carpet and remove the sound deadener if anything. It does help....
Quick Reply: PROJECT "UNLEASHED" (My 99' Trans Am)
