What are the pros and Cons of "De-Baffling" your Ram air hood?
So I was looking into a few MODS and I ran across the term "De-Baffling" your Ram Air hood multiple times. I understand the simple concept that it brings cooler air into the engin bay..... But I was looking for a little feed back from you all that may have been there and done it already. Is it a good idea?
My only concern is that my 01WS6 is 100% stock and I use her as my "Weekend Car" if you will. So i'm very careful on what I do that cant be reversed.... or does it even matter? I may be over reacting on this one. haha thanks for any help you guys may have.
Mine is a lot like your in the fact that its always in the garage and is scared of rain. haha
but I guess my real question is, Lets say I decide to do it..... How do i go about it? I went outside and was lookingat the hood. How do you get that thing out?!?!? lol
Debaffling smooths the flow of air through the hood, but its probably not worth it unless you also seal the hood to the airbox w/ a thick foam weatherstrip. I believe theres also a bead of adhesive holding the baffles to the inside of the hood in addition to the rivets, if that hasn't dried out and cracked by now, you might have to do some prying to break it loose after the rivets are removed.
I agree that sealed and at speed it would probably show some gain. Not enough to account for anything but since it's so easy to do there's really not a good reason not to do it either. Except the rain when applicable. And that has to be an extreme circumstance in my opinion.
I didnt know they had glue on them. Mine must have dried like you mentioned cause they just came right out.
[QUOTE=kyoytey1693;16397788]I agree that sealed and at speed it would probably show some gain. Not enough to account for anything but since it's so easy to do there's really not a good reason not to do it either. Except the rain when applicable. And that has to be an extreme circumstance in my opinion.
QUOTE]
I agree here I've done both of the the ws6s ive owned. bottom line it CANT hurt I rarely drive mine in the rain also.
QUOTE]
I dont know about the killing a motor to water thing. Even more so if you are running a clossed lid intake. I mean think about it. There are a ton of guys running SLP and Raptor hoods with the filters built into the openings.
I've been reading, and I think I'm going to do the baffle mod with my WS6 and the Volant. Reason being, for enough rain to get into the engine and hydrolock it, you'd basically have to be submerged. The filters (on my intake at least) aren't paper, and are a bit oily so they will stop moisture from getting through. As I've also read, the engine gets so hot, whatever drops might get in will probably evaporate very quickly. Avoiding puddles might be a good thing to do, but other than that, I don't personally see any reason not too unless you want to be super careful.
Well this sucks, I dont have any tool to drill out the rivets.... But thank you all so much for the replys. If I can find a way to drill out the rivets then I will do this for sure.
You also have to think if water does make it past the filter it would have to make it down the intake tube, past the maf, down the intake manifold, past the valve and cylinder heads, and into the chamber. At this point it should only be vapor and would not do any damage. Keep in mind we are talking about water drops from rain not running into a pond.
I noticed when I daily drove mine that when it rained hard water would be sitting on the metal plate that's under the air filter. What I figured was that there would not be enough suction to pull the water into the intake from there.
The only thing that I need to do is paint inside the nostrils where the baffles left a white ring.
1 Post
Here is the best pic I have of the filter setup
If your interested in seeing the underside of the hood let me know and I can snap a pic or 2 for you.
^^^ shortest distance of air flow.../ Ram Air... cool ambient air compressed on the leading edge of the bumper at a minimum designated speed that is forces said air into specific located air inlets located on a hood ... i say drill away! is won't help ,, last known real ram air was the LT1 Firehawks
Im running a raptor hood that seals to my filter setup, all the way around my big a$$ filter. Been DDing this ride for about 2 years thus far and havent had an issue yet.
1 Post
Here are a few pics of my setup, granted its slightly different due to the raptor hood.
I cant say there was any drastic performance difference, but when the hood is closed you can for sure hear the air getting sucked into the system. Also while driving if you get onto the throttle you can hear the intake as well.
Dang, Thats a sweet setup! I'm going to look into doing this for sure with my TA, Quick question....
If I buy a new SLP Lid (or whatever lid I buy) along with the LS1 JAAM Mod then would it be worth buying a Smooth Bellow also? I mean If I'm going to do this I always want to try and go top of the line and do it right.
"Firemech" On a side note.... your TA is so clean! Love the engine bay also. Nice work on that car.
1 Post
