The new ride
The new ride
I just picked this 98 Firebird up on Friday. It has some things that I want to change and or update but its an awesome car so far.
Performance Clinic in Xenia did the machine work and built the motor
Fresh 1999 block
GM Performance crank
Manley H Beam Rods
Diamond 12:1 pistons
Factory ported and polished heads
Manley Race Master Valves
Ported TB
Comp cam 572/576 lift 230/236 duration
Comp rockers
Comp roller lifters
Comp Timing chain
Performa Built 4L60E
Super Yank 3500 converter
Custom N20 kit
line loc
Bolt in 6 point cage
Spohn torque arm
lca's
Panhard
Weld in subframe connectors
Drive shaft loop
air bags in the rear - I am gonna remove these and put some QA1's on it
posi unit and 4:11 gear
I am sure I am leaving a few things out but thats off the top of my head.
Fresh 1999 block
Manley H Beam Rods
Ported TB
Comp rockers
Comp roller lifters
Comp Timing chain
Custom N20 kit
line loc
Spohn torque arm
lca's
Panhard
Drive shaft loop
Looks like a fast Formula. In the last week of August the Trans Am Nationals is held in Dayton. They normally have about 400 Firebirds. Check it out and congratulations on the new car!
The outer lights are the fog lights. The inner lights are the yellow running lights/turn signals.
