Cracked/broke my sideskirt, worth it to try and fix?
So I clipped a curb this weekend with my TA and the sideskirt cracked for about 1.5ft from the rear tire, forward, and a 6-8" section snapped off right by the rear tire :fuuuu: Now I'm going to try and get a replacement skirt (passenger side) and do all the work repainting and such by myself. What kind of work does it entail to repaint it (NBM), or would it be worth it to try and fix the crack/broken piece? I have the piece that broke off, and it fits back perfectly onto the skirt, just won't stay in place, obviously. I've looked into repairing broken fiberglass, and it appears it is, at least in theory, possible to repair, with just gorilla glue for the snapped off piece, and a fiberglassing kit for the crack down the underside. Has anyone repaired a skirt before, or done anything of the sort before? I'd like to repair it/get a new or used one on for as cheap as possible, asap. Please let me know what the best route is, and how I can go about doing that!
If it were me I would spend $10 or so on glue/fiberglass repair kit and get it looking the best that you can. It probably won't be perfect, but should look much better than it does now. Then if you decide you can't live with it the way it is, start looking for one off of a totaled car and you might be able to find one that is already the right color in good condition.
