true dual or cutout?
Old 05-16-2004, 08:35 PM
ctd03's Avatar
Default help
Alright Im Thinking About Putting A Qtp Single Cutout On My 2000 Ws6. Will It Sound Good? Give Me Ur Opinions. How Loud Will It Be And What Will It Sound Like?
Old 05-16-2004, 09:01 PM
ctd03's Avatar
Default Question
How Would I Run True Duals On My 2000 Ws6? And What Would It Sound Like?
Old 05-17-2004, 12:28 AM
2GFIREHAWK's Avatar
it will sound dope do it. i have one on my firehawk and i love it electric is the way to go
Old 05-17-2004, 06:54 AM
Angus's Avatar
Myself as well as xtincthawk02 have the regular cut out on our cars and they sound great and yes the electric one is easier to use with a flick of a switch. I don't mind manually un doing mine. Jeremy just leaves his off.
Old 05-17-2004, 06:58 AM
Angus's Avatar
Go to www.ls1sounds.com
Old 05-17-2004, 07:10 AM
Angus's Avatar
Go to www.ls1sounds.com and there are a few people on here that have the trual dual setups that you can get pics form and talk to about it.
Old 05-18-2004, 08:25 PM
Trans Am WS6 RGS's Avatar
Find a place that will make it for you,
And depending on the mufflers you use and whether or not you run the exhaust out the back it will be loud and sound great.
I can send you a sound clip of my exhaust if you give me your email address.
Old 05-20-2004, 07:11 AM
ctd03's Avatar
Default email address
ctd03@hotmail.com
Old 05-20-2004, 10:30 AM
Angus's Avatar
Here is my friend Vince's car with true dual.
http://www.angelfire.com/on2/Vinnie/truedual.html
Old 05-21-2004, 08:22 AM
STF Veteran
99-LS1-SS's Avatar
That is a VERY good looking set of true duels. Did the rear end shift when he move the PHB mount? That is exactly the way I want my true duels to look. PM me any info about cost and location if you can.
Old 05-21-2004, 09:25 AM
Angus's Avatar
Here is his name on the board. CySevans there is a post in the Texas section that you can use to send him a PM.
https://ls1tech.com/forums/showthread.php?t=172350
Old 05-21-2004, 10:50 AM
STF Veteran
99-LS1-SS's Avatar
Thanks.
Old 05-21-2004, 12:57 PM
Angus's Avatar
No problem.
Old 05-21-2004, 06:21 PM
ctd03's Avatar
Default true dual or cutout?
Which One B/t True Dual Exhaust Or Acutout Would Sound Better And Or Louder On My 2000 Ws6?
Old 05-21-2004, 08:21 PM
ataylors's Avatar
I had an idea of hooking it up to the brake lights so that when you stopped it would close and be quiet, then when you take off it would be loud again. I wonder if someone has tried this
Old 05-21-2004, 08:22 PM
ataylors's Avatar
I think true dual, but thats gonna cost a lot more
Old 05-21-2004, 08:48 PM
LS69TA's Avatar
Duals will sound better. A cutout is the cheap route, but I had duals on my Camaro after having: no muffler at all with dual outlets, 4" Spintech, and finally duals. This was my 2nd LS1 car, first was a 98 T/A 6spd w/o muffler and dual outets:basically the loudmouth but before it came out. It sounded good and was a cheap fix for loudness and had a good sound to it. Personally, I'll go true duals with Flow's again when I get another T/A. It is well worth the $. If you can find a small exhaust shop to do it, you will save a ton of cash. I paid $100 to have mine installed including the 3" pipe. I supplied the mufflers and x-pipe and some pics of how I wanted it done. Took about a hour and I saved probably 4-500 dollars. If you hear duals with the 1 chamber Flowmasters, you will be set on getting that setup. I have never gotten so many complements on the sound as I did when I ran that setup. Just my $.02 though.
Old 05-23-2004, 12:37 PM
ctd03's Avatar
Default exhaust sound
send me a clip of ur exhaust at ctd03@hotmail.com
Old 05-23-2004, 11:57 PM
Sent,
I dont always get a chance to re-read posts that I reply to so I didnt even know you had posted your email.
Old 05-25-2004, 10:23 AM
STF Veteran
TA TED's Avatar
Sounds mean as hell. My wife won't even ride in the car Yes you could wire it to the brake lights if you used the 12 light blue wire on the brake switch to close a relay tied in parallel to the close circuit of the switch.
Quick Reply: true dual or cutout?
