Engine Mounts
Old 07-25-2008, 09:16 PM
cherryelky305's Avatar
Default Engine Mounts
Not sure where else to put this one. Me and a friend are swapping a v6 to a v8 in a '84 firebird. He couldnt get the old engine mounts off, so he came up with a plan. He's going to heat the bolts up then use an air chisle (sp) to knock off the tops. Once thats done he plans to just weld (aka, have someone else weld) the new mounts in place. Opinions? i think there is a better way to do it.
Thanks.
Old 07-26-2008, 11:57 AM
svtwhat?'s Avatar
you do realize there are nuts on the bottom side of those bolts and you have to reach up inside the k member to hold them right?
Old 07-27-2008, 02:41 AM
yeah i know, and i told him that but he cant figure out how to get it off, I'm just helping its his car, lol.
Old 07-27-2008, 06:29 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Grind the bolt heads off.
Old 07-27-2008, 06:58 PM
Drumer919's Avatar
I dont know about the 3rd gens but I know for sure (cause I did it) with the 4th gens you CAN NOT just change motor mounts, you have to swap to a V8 k member, might want to figure that out before you possible waste time trying to get those bolts out.
