Pontiac G8 2008-09 & Chevrolet SS 2014+ LSX based RWD 4-door sedans
G8 GT Rear End Swap
Old 03-13-2012, 06:56 AM
  #41
SREETRACEGUY's Avatar
I got a 3.45 camaro rear i'm doing the posi mod then putting it in asap
I got the RotoFab CAI.
Old 03-17-2012, 11:42 PM
  #42
BEN2007SS's Avatar
I have the 3.27 gears and very nice mod for my car. 0 to scare the s--t out of you for sure.
Old 12-04-2012, 12:58 PM
  #43
jlasti's Avatar
Default camaro to G8 diff swap
I have been told that when doing the camaro to g8 diff swap, you have to replace the axle also. Due to the mounts and splines.
Old 12-04-2012, 01:03 PM
  #44
Rawyzf's Avatar
That is 100% false.
No axel swap needed.
Old 04-14-2013, 12:44 PM
  #45
Brian_Sonier's Avatar
Default new to forum
Hey guys i have 2009 G8 GT im new to the forum, i also have a 3.27 camaro rear and i love it. ALOT faster off the line and gained alot of midrange power which is exactly what i was shooting for since i only use it for street use.
Old 04-29-2013, 03:28 PM
  #46
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
So conversely, will a G8 center section bolt up right into a 2010 Camaro SS?
I'm looking for a whole center section so I can do 3.91's (maybe).
Old 04-29-2013, 08:33 PM
  #47
SLOW SEDAN's Avatar
It would bolt up, but you would be going to a smaller housing and ring gear... Why not just get a 1LE diff? Probably cheaper by the time you buy the gears, rebuild kit, etc..
Old 04-29-2013, 09:26 PM
  #48
LS1Tech Co-Founder
So the G8 setup might be less sturdy?
A full 1LE diff is interesting but new they might be $1500?
Old 02-11-2015, 06:22 PM
  #49
Dajuan Brooks's Avatar
Originally Posted by G8RAM
OP HERE,
I've seen a lot of comments, on several forums that tuning new gears is difficult.
I mentioned that to my tuner and he looked at me like I had three heads!!!!
Using HPTuner, he completed the tune is less than 5 minutes and it was spot on.
I checked miles per hour with my GPS and it was perfect.
He had to enter the tire size, and new gear numbers. Computer automatically made 103 changes to my setup.
As usual it comes down to the knowledge of the tuner.
Good Luck!!!
was your tuner brian from dynotune motorsports
Old 02-11-2015, 07:45 PM
  #50
G8RAM's Avatar
Yes!!
He is the man....
Old 02-12-2015, 03:28 PM
  #51
vettewreck's Avatar
Where are u guys buying the Camaro 3.45 differential for the G8 auto swap?
Old 02-12-2015, 03:36 PM
  #52
LS1Tech Co-Founder
They come up on Camaro5.com for example.
Old 02-14-2015, 06:58 PM
  #53
vettewreck's Avatar
Any other places to find a 3.45 rear differential?
Old 02-14-2015, 08:57 PM
  #54
G8RAM's Avatar
Sometimes you see them on Flea Bay.....LOL
I missed the opportunity to 2 or 3 times in the last couple of months.
Seems like there have been more 3:91 gears and for me with an auto that maybe too much gear....
I still like my 3:27's but hoping for better ET's in the 1/4 mile.
Old 03-31-2016, 08:37 PM
  #55
Camaros-n-Chevelles's Avatar
Has anyone heard of the Steel Clutch Disc and Shim Kit Upgrade?
http://www.ebay.com/itm/161069391388...84.m1555.l2649
Old 09-10-2016, 06:16 AM
  #56
gt_owner's Avatar
i am interested in the camaro 3.45 diff. does anyone know the part number of the diff. and where can i get one? is it okay to buy a used one?
Old 09-29-2016, 04:40 AM
  #57
vroom_vroom's Avatar
Keep hitting the bone years, if you can find a v6 rear end that was a 6 speed manual it's the same rear end as the ss. 3.42 post with the better axles.
Old 09-29-2016, 04:55 AM
  #58
S2KIWI's Avatar
I have experience with both the GXP and the g5/ z/28 diff, yes they use the same axles, also confirmed by DSS.
And yes same with the G8/Holdens, V6s have same diffs as V8s, only difference is the V8 HSVs are shot peened and a little stronger.
The Camaro diff is a beefier unit for sure, much more webbing on the pumpkin.
Old 01-17-2017, 11:41 PM
  #59
SAG8's Avatar
Default Diff swap ?
Did you swap the whole pumpkin on your pontiac g8 gt man ?
Old 03-08-2017, 10:54 AM
  #60
Spectre86's Avatar
what was the rpm difference on the freeway doing 75mph? curious what it is with the 3:45 as well. 1mpg isn't bad at all.
Quick Reply: G8 GT Rear End Swap
