Pontiac G8 2008-09 & Chevrolet SS 2014+ LSX based RWD 4-door sedans
G8 GT Rear End Swap
Old 03-15-2017, 10:29 PM
  #61
DoUSail2's Avatar
I lost time (.04 seconds) through the 1/4 mile putting in the 3:27 over the 2.92's. I was passing through the traps in third gear with the 2.92. I'm part way thru 4th with the 3.27's but I don't think the extra getup makes up for the lost time of the extra shift. Bottom line is I like the 3.27's on the street, definitely more get up and go but if it's 1/4 times your interested in definitely go big (3.45's).
Old 05-03-2017, 07:27 AM
  #62
ksteed94's Avatar
Do you mean lost .004? What was the time you ran with both rear ends? I just order a rear diff, thinking about returning it now.
Old 05-03-2017, 10:39 PM
  #63
DoUSail2's Avatar
Nope I went from 12.27 best with the 2.90s and 12.31 best with the 3.27s; lost 0.04 seconds due to the extra shift. It is peppier on the street but like I said, if the 1/4 time is all you care about get the 3.45s. It all depends how much power you are putting down and what RPM you are at when you pass thru the traps. You really want to have gearing that allows you to get over 6000 RPM when going over that finish line so you are taking advantage of most of that last gear.
Old 05-23-2017, 03:32 PM
  #64
Gravedigger1's Avatar
I did a 345 swap. awesome runs about 22-2300 at 70ish killer out of the whole. came headers head work pat g tune for engine and trans. hits supper hard into 2nd and 3rd if you stand on it 20' rims with 255 35 20's
Old 12-09-2018, 04:22 PM
  #65
Charles Williams's Avatar
Default Are the g8 and camaro diff the same? I want to purchase a 3:70 g8 gear for my camaro
Originally Posted by G8RAM
A couple of friends and I installed a 2010 Camaro 3:27 differential over the weekend in my G8.
The swap is worth the effort for performance and reliability.
I selected the 3:27 gears because I'll be installing a blower in the future and from what I've researched, a 3:45 or more gear blows the tires off.
The car certainly feels lighter and I'm pretty sure will improve my 60' times.
The swap took us about 4 hrs. and I already had the bushings installed in the differential.
Any questions you have about swap, just ask away.
Are the g8 and camaro diff the same? I want to purchase a 3:70 g8 gear for my. 2010 camaro ss
Old 01-23-2019, 09:00 AM
  #66
G8 Joel's Avatar
Default My G8 gt
Agree, people launch blown cars with 1,000hp with no problems on the correct tire. Actually I've seen them go down the track on a 275 radial...
Nice, I've done the Camaro rear swap into the G8 about 5 times now and have it down to about an hour and a half. I've also done the Driveshaft Shop 9" conversion which the ultimate upgrade. The Camaro rear is a decent upgrade and you notice the size of the Camaro rear next to the OEM G8 diff. I would always go with the 3.45's but even the 3.27's, just put a real tire under the car and you wont have any traction problems.
Sounds like whoever has issues needs real tires and suspension upgrades! There are numerous people launching 600+hp cars with 3.70+ gears with no problems. The toe, trailing, and control arms need to be upgraded to take the movement out when launching. You can see the tire move back with the stock arms/bushings, if you cant keep the drivetrain straight then of course your going to have traction problems.
I've made a mistake , I ordered 3.27 for G8 gt but they came out of a v6. Can I still use it or I'll have to order one . Off of a V8 ??? Someone please help me !
Old 02-01-2019, 09:25 AM
  #67
L78steve's Avatar
Take a picture of the label and post it.I will compare it to my 3.27 diff. from a Camaro SS.
Old 02-02-2019, 01:38 PM
  #68
SLOW SEDAN's Avatar
If the Camaro was manual V6 then its the same diff as auto V8.
Old 07-31-2022, 03:58 PM
  #69
RDGRAYRN's Avatar
Default Camaro and g8 rear yoke l
[QUOTE=Rawyzf;16949370]That is 100% false.
No axel swap needed.
are the camaro and g8 rear yokes the same?
Old 05-14-2024, 04:46 PM
  #70
SimonYG8's Avatar
Questions!!! Would I be able to put a 2015 Chevy ss 3.27 diff on my 2009 g8?? Does it need to be a certain year Camaro and do I need anything before I swap it?
The following users liked this post:
RDGRAYRN (05-14-2024)
Old 05-14-2024, 11:13 PM
  #71
RDGRAYRN's Avatar
Yes that is exactly right. I have 2010 camaro ss supercharged with 3:91 gears and 1st&2nd gear at full throttle is useless.
Quick Reply: G8 GT Rear End Swap
