Pontiac GTO 2004-2006 The Modern Goat
Gforce Engineering is now a site sponsor
Old 09-15-2009, 12:35 PM
m_williams's Avatar
Originally Posted by Gforce Engineering
Inner axle stubs
We make 4 versions of inner axle stubs.
Again I am very proud to say that none of our stubs, bolt together or one piece have ever been twisted or broken. Not a single failure!
A 28 spline that is the factory size and we also make a large 33 spline stub.
Our 33 spline stubs are designed to be used with our line of 33 spline spools and soon to be released line of 33 spline Eaton Truetracs.
Our 33 spline stub is the largest and strongest stub on the market. And is also larger then the 8.8 products out there.
All are made from billet 300m steel and heat treated with the best process in the industry to give you the best product out there. Our stubs have a little higher Rockwell hardness than most on the market.
We were the first and only company to bring you a revolutionary bolt together stub that is fully up or down gradable to either our 28 or larger 33 spline stub axles.
You said it.... Or are you just boring the 28 spline ones and resplining to 33 splines?
m_williams is offline
Old 09-15-2009, 12:43 PM
Gforce Engineering's Avatar
Oh yea, that's just us making the 28 splined truetrac into a 33 spline.
We bore out the case and then cut the spider gears to 33 spline on an EDM wire machine.
I wish Eaton would come out with one, they could do it cheaper then we can. Would be a great product for them.
Chris
Gforce Engineering is offline
Old 09-21-2009, 04:46 PM
plumcrazy1's Avatar
Great sponcer and guy to deal with. He also does a great job of keeping in contact with you even for some questions that most may not answer....
plumcrazy1 is offline
Old 09-22-2009, 01:32 PM
Thanks man! I appreciate that
Old 08-17-2014, 06:18 PM
54inches's Avatar
Do you sell you CTSV 8.8 inner 31 spline stub shafts that bolt to the 930s?
54inches is offline
Old 08-18-2014, 01:02 AM
EFoxwell's Avatar
Holy thread revival.
EFoxwell is offline
Old 08-18-2014, 07:40 PM
54inches's Avatar
It's not a thread revival, it is a matter of searching for what I was looking for and finding it instead of clogging up the site with useless new threads that have been answered 1000 times.......thanks for your input though.
54inches is offline
Old 08-20-2014, 12:34 AM
EFoxwell's Avatar
Or you could have just sent GForce a PM, but hey, surely you'll get a response in this old thread in the GTO section.
EFoxwell is offline
Old 08-21-2014, 12:33 AM
54inches's Avatar
I sure hope so!
54inches is offline
Quick Reply: Gforce Engineering is now a site sponsor
