car is stalling
car is stalling
so been having problems for a while and ive been going over some things cleaning checking for vacuum leaks and what not but i cant find any vacuum leaks, just cleaned my throttle body, new MAF sensor, cleaned air filter, but when i start my car up it idles fine. idles a little high, around 800, but its steady. when i put it in gear RPM's immediately drop to 600, put it back in park rpms stay at 600. now when i have too many things running like AC or heat and i have my lights on and what not, the rpms drop to around 400. after this happens the car starts to lope bad and rpms jump around and eventually cuts off. i have taken it to 3 mechanics. one says loose wiring somewhere, another says bad tune or pcm is bad, another swears up and down a vacuum leak. has anyone had these kind of problems and could maybe give me a more definite answer?
i know what codes its been throwing. the first time i got it checked out it was saying bank 2 o2 sensor system 2 lean and MAF sensor was bad, i changed the MAF and changing the o2's on the first. after i cleaned the throttle body it came up something where the blade was catching or something but i fixed that also.
yea ive been told that wires under there can get pinched and call the car to start messing up but ive also checked that as well. i mean im no mechanic but the wires did not seem like they were in a bind in any way under there.
if it is custom tuned you may want to talk to your tuner and just have him set the idle up a little more. he should be able to. i have mine set to about 1000 rpms but thats to help hide the big cam a little bit.
well see i have had this tune for about 2 years now and its just now starting to mess up. so i know there is definitely something wrong with the car and even if i get the idle raised, in the back of my mind im still gonna know theres something wrong with it so i just really want to get it fixed. oh and for future reference for anyone trying to help me out, i have also had the fuel pump checked out, its working right 2....
