Pontiac GTO 2004-2006 The Modern Goat
Shift RPM?
Old 05-10-2011, 06:15 PM
RedfoxGTO's Avatar
Default Shift RPM?
So I have a predator tuner for my 04 gto LS1 and I assume the previous owner tuned this car, So the mods I have (many already know) American Racing longtubes, catless mids, spintech x-pipe and side boxes, and and the predator of course, So here's the thing, The Shift RPM is set to 6400 into second gear, and when I set the factory tune it still shifts at low and behold 6400 RPM.... that seems a little dangerous, I wanted to just go stock but the tune seems to be stuck on the car, So what I want to know simply is, how can I remove this tune, why when I try to flash factory tune back on it wont come off?!wtf?, and is this a bit much for a mostly stock motor? YIKES!
Old 05-10-2011, 11:28 PM
impulsegoat's Avatar
I had mine set at around 6400 rpms with the diablo handheld too. I don't think you will have to worry about hurting anything. I found from testing and tuning with it at the track that i would usually trap a bit better mph and run around a 1/10 quicker in the 1/4 when i had it shift at 6400 into 2nd as opposed to stock around 5900.
Only thing i could think of why it wouldnt return to stock tune when you load the stock tune back in is if the car already had a tune in it when they put the diablo in. If you remove the diablo and the car runs the same i would just sell it and make some extra mod money.
Old 05-11-2011, 04:56 PM
NasbaGoat's Avatar
no worries... my limiter is set at 6700 RPM...... 92K and rollin
Old 05-19-2011, 12:05 PM
1.BAD.GTO's Avatar
mine is also @ 6700 and still rolling... U just go sideways on secord and it just hp tuned & cai...
Old 05-26-2011, 03:46 AM
sfuller442's Avatar
6400 is very safe. i go to 7k and its seen past that on accident
Old 05-26-2011, 02:45 PM
1.BAD.GTO's Avatar
MY guess is if the previous owner tuned it and didnt give u the hand held that the car was tunes in the first place thats maybe why ur having trouble...
Old 05-28-2011, 11:34 PM
Joeyelbows's Avatar
You should bump up the shift rpm and please for the love of god get that 12 second pass!
Old 05-31-2011, 08:49 AM
mark21742's Avatar
I have my shift rpm set at 7,500 rpms now....but I have a few mods....6,400 rpms should be a good short point for you
Quick Reply: Shift RPM?
