Pontiac GTO 2004-2006 The Modern Goat
rwhp predictions?
Old 11-10-2011, 11:34 AM
Nastynotch's Avatar
Default rwhp predictions?
In the process of building up my buddies 04 gto. Diamond pistons, eagle rods, afr 210's out of the box, fast 102 intake, 100mm tb, 100mm mass air, svede otrcai, 42lb injectors, fast fuel rails, spec'd comp cam, speedinc pushrods, kooks long tubes, magnaflow cat-back, spec stage 3+ clutch, 1 piece ds,and level 5 axles. Lots of misc parts.. im kinda new to the gm crowd, but from what I can gather it should be around 450rw? Its still gonna be 346 ci
Old 11-10-2011, 12:31 PM
700rocket's Avatar
Not knowing you CR and cam specs, I would bet it will be more like 415.
Old 11-10-2011, 12:42 PM
Nastynotch's Avatar
10.6:1 cr, and .600 lift /235 @.050.
Old 11-10-2011, 02:35 PM
Buzzmanb12's Avatar
450+, heads, cam, intake, exhaust and all the other mods. Should be sweet.
Old 11-10-2011, 04:42 PM
blk/slvr02ss's Avatar
I Would say 435 rwhp.
Old 11-10-2011, 06:07 PM
402GOAT's Avatar
since its a six speed car you may hit 450ish but i wouldnt put my money on it. id say more like 425ish.
if it were my build, id save the money on the level five axles and go with a level one or two in the anti hop setup and spend the extra on a good port job of the fast intake.
Old 11-10-2011, 06:23 PM
svede1212's Avatar
It will also depend a large amount on the dyno. I've seen differences on mine of 415 to 460 depending on the dyno. Just take it to a track, log some traps, find the DA and see where you're at.
Old 11-10-2011, 06:39 PM
Nastynotch's Avatar
We'll definatly be taking it to the track. He wants to outrun my mustang, but I dont think its gonna happen because im running 11.00's all motor with a 150 shot if need be.
Old 11-10-2011, 11:58 PM
impulsegoat's Avatar
435 is a nice goal. Anything more than that id be pretty happy with.
Old 11-11-2011, 07:42 AM
04gto5.7's Avatar
id say 430 to 440 given you have a friendly dyno
Old 11-11-2011, 01:50 PM
Nastynotch's Avatar
Im gonna take plenty of pictures and make a build thread when its all done, and tuned.
Old 11-11-2011, 08:25 PM
GT-OH's Avatar
In the 430 range.
Old 11-11-2011, 10:37 PM
ShoddyHog's Avatar
Evan Goding says it will be 420.
http://www.youtube.com/watch?v=ZHdjqsSSa_A
Old 11-17-2011, 08:42 AM
CPower06's Avatar
With a good tune, depending on the cam specs, and assuming you didnt LOWER the CR, Id say 450 is a very reasonable goal.
CPower06's Avatar
Originally Posted by shoddyhog
evan goding says it will be 420.
http://www.youtube.com/watch?v=zhdjqsssa_a
rofl!
Old 11-23-2011, 06:52 AM
scphilli's Avatar
400 - 420 is my guess
Old 11-28-2011, 08:09 AM
Nastynotch's Avatar
If thats all these motors make with every availible part swapped to the best stuff, then it truely makes me proud to be a Ford man.
Old 11-28-2011, 06:30 PM
It's going to make at least 425 to the ground with a potential of up to 450-455 range. I don't know about you but id rather set reasonable goals and then if you exceed those goals be happy with it. Instead of saying well a few guys made 450+ out of their 346 so anything less than that is basically a disappointment. He will be very happy with the car and the numbers if the build goes well.
Old 11-28-2011, 06:38 PM
Also, no way in hell you should be guessing 400. Iv seen stock ls1's with a cam swap, cai, and longtubes putting down anywhere from 385-405 depending on dyno and air. If he puts everything listed in the original post it will easily be in the 435-450 range imo.
Old 11-28-2011, 07:21 PM
scphilli's Avatar
Predictions were requested.......so that is all I provided. It was kind of a wide open request without providing cam specs and my guess was based on the GTO drive train being pretty parasitic (eats between 18 and 20% of the engines power). You cant compare it to an LS1 in a vette or F body, the numbers will be less.
Also, it is well documented that the cathedral port FAST 102 does not show any significant gain over the LS6 intake on stock cubes. While the list of parts may be impressive the majority of them add durability and not power.
I hope the numbers end up being more and I am sure the owner will love the gains regardless of what the numbers end up being.
Quick Reply: rwhp predictions?
