Do I have 3.73s???-'04 m6 people step in.
I'm trying to find out if I have the stock 3.46 gears in the rear or if mine have been swapped out for 3.73s... After some talk about top speeds on an FB page and some guys throwing out numbers in some gears that made no sense to me, I decided to do some calculations using this> http://ultimategto.com/art29.htm top speed calculator.
Yes, I'm fully aware that I can crack open the dif to find or or simply jack up the rear, spin a wheel, and count the driveshaft revolutions. The problem with that is: My jacks and lift are at my shop and as I'm a full-time student and working-part time, my GTO rarely leaves the garage. Not knowing the answer to this question is just going to bug me so I figured some of you would be able to help me.
As the title states, it's an '04 6-speed... I bought it last July from a private owner with 61,xxx, but was only told of the K&N, ported TB, Headers, custom catback, and Hurst. I was told it's still got the factory tune on it so I jut assume my redline is right around the 6k RPM so I shift at (roughly)40-60-90-120 which, according to the above calculator, seems to be consistent with 3.73s. I asked a local '04 m6 buddy his shift points and they were the same as mine. He bought his with 14,xxx in 2009 from a guy who used it as a showcar. The only mods he was informed of were a K&N and SLP LMII catback (it's much, much more than that now)...
Enough with this damn novel. '04 m6 peoples, tell me: At what speeds (roughly) are you shifting (If you shift after 6k take that into account)? Do my speeds seem to be consistent with yours? And finally, do I have these freakin' 3.73s or not???
Thanks
Brandyn
Edit: Forgot to mention that I noticed a very slight leak in my dif last time I had it on the lift. That was another thing that led me to possibly believe someone did some messing around back there...who knows.
Thanks
Brandyn
**** it. I'll just throw it on the lift next time I take it out.
Your questioning would still require factoring in your tires.
It's a lot easier to ask "At what RPM is your car at 70 MPH?". (and a lot shorter too!)
Almost everyone can tell you what you have then. Those gears would make a 7% difference in RPM.
Sadly it's pretty common to have untouched diff leaks.
can't really give an accurate speed/rpm because I'm on a 245/45/18 now
Grab a GPS unit that displays vehicle speed, see what RPM you are at 60mph then go plug in all your relevant information into a gear calculator and see at what rear end gearing matches your cruise RPM.
Nothing with this car seems to surprise me anymore.
How accurate is a GPS unit really going to be, though?
Plus you don't need to be dead accurate, you just need to get a rough MPH/RPM reading to match up to the rear end.
