Pontiac GTO 2004-2006 The Modern Goat
Oil pump options ?
Old 05-16-2013, 06:15 PM
Oneslowgo's Avatar
Default Oil pump options ?
I am doing cam swap on ls1 gto I am putting in a torquer v2 cam what oil pump should I use? Ls6 ported ?
Old 05-16-2013, 07:23 PM
Cajun ELESS-ONE's Avatar
ls6 ported or a melling are your best options
Old 05-18-2013, 09:31 AM
Canada's Avatar
Melling HiVolume.
Old 05-18-2013, 09:00 PM
409CISecondGen's Avatar
I bought a ported LS6 from Texas Speed.
Old 05-20-2013, 10:26 PM
Oneslowgo's Avatar
Thanks going with ported ls6
Old 05-25-2013, 11:35 PM
gconnoyer's Avatar
Originally Posted by Canada
Melling HiVolume.
No, Melling high pressure. Unless you want to risk sucking air...(unless you've got a higher capactiy pan.
Old 05-26-2013, 02:01 AM
Canada's Avatar
The HI Volume still comes with a high pressure spring. I just double checked and my 408 has the high pressure melling, 10295 is the part number.
Old 05-27-2013, 02:21 AM
AZGTO's Avatar
I went with a Melling 10296 and switched the spring to the blue spring. No issues at all
Old 05-27-2013, 08:29 AM
+1, high volume stock pressure is the way to go.
Old 05-30-2013, 06:51 AM
Canada's Avatar
That is what is how they recommended I do it in my 408 but my cam only one was the other way around. I figured Tsp knew a lot more than me.
Old 05-30-2013, 07:46 AM
mebuildit's Avatar
I used a TSP ported pump in mine over a year ago, no problems. I run royal purple and in the Az. summer heat it holds 55-60PSI on the freeway. Idle, is around 32-35psi.
Quick Reply: Oil pump options ?
