Pontiac GTO 2004-2006 The Modern Goat
04 lean cruise ive tried everything
Old 12-11-2014, 10:23 AM
freds53's Avatar
Default 04 lean cruise ive tried everything
I purchased a 04 gto ecm for my build . I have a 91 s10 5.3 4l80e I know lean cruise only works on 04s since it was a "holden". I have read and read and set my multiplier up in hp tuner for some reason it still won't go into lean cruise.(watching with WB) Here is what I did I pulled the stock 04 gto file off and flashed the file I had in my 04 express van PCM that was already set up for my 5.3/80e is that possibly why it won't enable? I thought the coding that told it that it was a holden was hard coding.
Old 12-11-2014, 05:38 PM
svede1212's Avatar
There are several parameters that have to be set for LC including enable speed, etc. Here's a link
http://www.ls1gto.com/forums/showthr...ht=lean+cruise
Old 12-12-2014, 04:50 PM
freds53's Avatar
I populated all the tables like shown on that post but still won't go into lean cruise I'm not sure what I'm missing.
Old 12-13-2014, 04:00 PM
GotToGo's Avatar
Make sure you're in Closed Loop. Its required for LC.
Old 12-21-2014, 09:54 AM
svede1212's Avatar
Why don't you post up your tune and then we can see where it's different. Much better than guessing. BTW I run mine in complete open loop and it works fine.
Old 12-26-2014, 07:34 PM
Rob
Rob's Avatar
^^^ that would be the easiest thing to do.
Quick Reply: 04 lean cruise ive tried everything
