LS3 Heads/Cam Swap
LS3 Heads/Cam Swap
Figured I'd start a thread here. Just finished up my LS3 Heads/Cam swap on my '06.
Parts List:
GMPP CNC Ported LS3 Heads 68.5cc
Cam Motion 226/232 .626/.626 112+2 LSA
Ported L76 Intake, Rails and Injectors
BTR .660 Dual Springs, Titanium Retainers
BTR 5/16's Push Rods
LS3 Rocker Arms w/ BTR Trunion Upgrade
TSP U/D Pulley (Couldn't use, defective part. Just slid right onto the crank snout)
GMPP High Volume Oil Pump
C5R Timing Chain
SLP 160* Thermostat
Cometic .040 Head Gaskets
GM Timing Cover, Valley Pan, Water Pump Gaskets, Front Seal, Head Bolts
ARP Cam Gear Bolts
Mods Already Installed:
Svede
Pacesetters
SLP LM2 Cat-back
LS7 Clutch
Parts List:
C5R Timing Chain
SLP 160* Thermostat
ARP Cam Gear Bolts
Svede
Pacesetters
SLP LM2 Cat-back
LS7 Clutch
