Need some help- No start, no interior power
1 Post
Here's the scoop. '04 A4 GTO, replaced the starter a couple weeks ago as it was dragging. For some reason I had to re-delete security to get it to start and idle, but once that was done, no problems. Wife drove it to work 2 days, brought it home the second evening, shut it off. The next morning, keyless worked per usual, but nothing on the dash responds to the key. No DIC, no radio, the only thing inside the car that works are the interior lamps and hazards. I've checked all fuses, swapped relays, and no change. As a matter fact, as of now, the PDLs now refuse to respond to the fob, although it will flash the exterior lamps. I'm sure I'm not the first with this issue, hopefully someone can shed some light as I'm getting tired of messing with it.
Did you check the wiring behind the glovebox yet?
This thread was a few down from yours...
https://ls1tech.com/forums/pontiac-g...-key-vats.html
