First oil change / big skid plate
I changed the oil my my '04 GTO for the first time at 1000 miles to get the break-in oil out.
Whoa! What a skid plate.
Dropped the skid plate to get access to the oil pan and filter. That skid plate is pretty beefy for a sports car. The Aussies must use it for Kangaroo squishing.
My car had a PF44 filter (old style) on it. The owners manual said to use a PF46 filter (new style). GM must have been using up their old stock of PF44's.
I was also surprised to see that the GTO takes 6.5 quarts of oil. I thought I was refilling the Exxon Valdeeze for a while. I'm used to my F-body only taking 5.5 quarts.
Is the skid plate under the GTO's a structural memeber for the car? It didn't seeem like it when I looked. The skid plate seemed beefier than the one on my Tahoe.
It is not a structural piece.
This car has a Rear steer chassis in that all steering rack and compenentry is behind the centerline of the front axle. In order to accomodate for this, Holden had to implement a new oil pickup which also required a different oil pan with it's sump on the front half of the motor. SInce there really isn't a big cast "K" member like the F-Body to absorb impacts with any objects, in order to protect that oil pan, they installed the skidplate.
Personally, since I don't go off roading with mine, I took the skidplate off completely. It weighs like 15lbs. There are aftermarket ones available like the BMR unit, but I just left it off.
Agreed, the stocker is a PITA. If you want to keep something there, get the BMR skidplate. It looks good, and is much lighter than the cast iron stocker. I drove a week or so without one at all, but with the car sitting about 1/2" lower in the front, I thought I should put one back on.
Check with the sponsors, many have 10-15% off BMR stuff, that's how I got mine.
www.cmotorsports.com was the place.
This may be 'urban legend' but I thought that I read either in this board or another that the purpose of the plate was either or also to aid airflow/cooling. The point that was made was that removing it or putting in one of the aftermarket plates that has large gaps in it defeats the purpose. Appreciate the definitive answer as I am contemplating changing out the plate.
It was so obnoxiously loud that I had to put catalytic converters on to quell some volume and the rasp it had.
When the windows were closed, it vibrated stuff inside the car. When the Fiance heard me get on it about a mile away came the order to quiet it down or else she wouldn't get in the car.
At WOT it was on par with my heads and cammed Camaro for volume. There's a sound clip in this section somewhere (with cats) of me getting on it in 1st as well as an idling and revving .MPG file
Personally I think it sounded great (although I don't care for rasp) as long as the windows were open, but when closed, even I was annoyed with it after awhile.
For what it's worth, the source of the cooling purpose of skid plate was the Holden manual from what I read on another Board. Not sure whether it really serves that purpose or not but did want to pass it along.............as someone also noted on that Board if it was cooling only, why not thick plastic which was a good point.
"An oil pan under-tray (1) also forms an integral part
of the air flow system around the GEN III V8 engine
and must always be reinstalled after removal for
service operations, such as engine oil draining and
oil filter replacement.
NOTE: This tray is not designed as an oil pan
stone guard."
stone guard."
stone guard."
stone guard."
I guessed Kangaroo squisher (or stone guard).
I ordered the SLP skid plate. It is not solid like the stock one. I bought it for this reason so i didnt have to take it off to change the oil. I havent even recieved it yet so i cant say yet if it drives?? any different. What do you guys think? Does it need that solid skid palte on their for aerodynamics? Is it not going to be as stable at high speeds? i dont want it to create a parachute under my car.lol
